Speaker Cable
Discussion in 'Home Cinema Speakers' started by MATT JENNER, Apr 29, 2003.
  1. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    374
    Gravesend/Kent
    +8
    I have acoustic energy aesprit series speakers, and i have bi-wired them onto my Denon3803 amp,
    As the ends (amp end) are bare wires, would it cut down the signal/degrade it in anyway if i solder over the ends before they go into the amp?
  2. Sunday Ironfoot
    Sunday Ironfoot
    Possibly unless you use solder with a high silver content, bare wires are fine to be honest, just twist them around to stop any small wire filaments poking out. Alternatively use banana plugs.
  3. nathan_silly
    nathan_silly
    I wouldn't worry about it. What do you think joins resistors, transistors and capacitors to the PCB tracks?
  4. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    374
    Gravesend/Kent
    +8
    Thanx Guys for the help
    is there any banana plug you would recommend ?
    thanx again
    matt
  5. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    374
    Gravesend/Kent
    +8
    i have seen these 2 types of banana plug which is the best
    bearing in ming i am cack at soldering
      Size:
      20 KB
      131
  6. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    374
    Gravesend/Kent
    +8
    and here is the other one
      Size:
      25.4 KB
      128
  7. MikeK
    MikeK
    If you are "cack" at soldering, you may be better off with the second set - the first set look like solder types while the second set are screw on.
    Just be careful with all metal banana plugs - it's very easy to touch them together (nothing a quick bit of tape can't fix though :) )
