Speaker Cable
Discussion in 'AV Receivers & Amplifiers' started by bamber, Feb 28, 2003.
  1. bamber
    bamber
    Dec 2, 2002
    212
    16
    I am about to add a set of B&W Nautilus 803's and a Bryston 4B SST) for side speakers to the following setup:-
    4 x B&W 803's
    1 x B&W HTM1
    1 x Bryston 6B SST
    1 x Bryston 4B SST
    1 x Tag AV192
    1 x Arcam DV27
    Currently I use Nordost Red Dawn Biwire for the front channels, Blue Heaven for the Rears and Red Dawn Interconnects.
    My cables are all hidden behind skirting boards.
    As I don't want to take my skirting boards off again can anyone recommend cable for this setup. Preferably the new cable would be tough enough to be stepped on and not the flat type.
    I have never owned anything but Nordost so would like to here other positive views on other brands.
    This is not a cheap versus/ expensive thread as this has been done before.
  2. nathan_silly
    nathan_silly
    Rega makes some semi-flat cable (flat, but not as flat as the Nordost) at £2.50/m.
    Can take a snapshop if yer want.
  3. bamber
    bamber
    Dec 2, 2002
    212
    16
    nathan_silly do you use Rega in your setup?
  4. nathan_silly
    nathan_silly
    Yeah, for my AV L/R's. Flexible, easy to strip.
