speaker cable
Discussion in 'Home Cinema Speakers' started by IGADHIA, Jun 17, 2002.
  1. IGADHIA
    IGADHIA
    so I have pretty much decided on the set up for my upcoming cinema room.
    denon 3802
    kef eggs with 2 subs
    panny plasma
    xbox
    digibox
    tivo?
    dvd player
    ok so what are you thoughts on speaker cables? brand? type? no worried about shape as I will be running these from inside of the walls and ceiling, totally invisible. running them to a face place at the from of the room where I will plug them into the Amp.
    I am not rich so price Vs Quality please!
    thanks a lot.
    (also any ideas about interconnects would be greeet!)
  2. graham.myers
    graham.myers
    If £5/m isn't breaking the bank QED Anniversary Silver is a good choice.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Good cable but should be available for £4.50 if you look around
  4. Jase
    Jase
    Mar 16, 2001
    10,724
    United Kingdom
    +2,500
    Have a look at www.chord.co.uk
    Their Carnival cable is about 5 quid a metre.
  5. bob007
    bob007
    Agree with Graham QED S/A is a good choice, and can be found cheaper than £5m if you take some time and check out the different prices.
    I notice you have put down on your list Tivo? and Digibox, have you looked at the Sky+ system, think Tivo has a few more features but Sky+ has 5.1 sound on selected programmes, and you will have one less box in your room, just a thought.
    bob
  6. graham.myers
    graham.myers
    It depends who you want to give your money to.
    £10 month for SKY + or £199 lifetime to TiVo
    I went the latter, Mr. Murdoch gets enough of my spondollies
    [​IMG]
