SPEAKER--CABLE???????????
Discussion in 'Home Cinema Speakers' started by mongo, Jul 20, 2001.
  1. mongo
    mongo
    I AM USEING A IXOS 103 ( DUNNO WHICH ONE )
    10 METER CABLE FOR MY SUWOFFER WITH LOCKABLE GOLD CONNECTERS ( THE SCREW TYPE) IS THIS A GOOD CABLE TOO USE???
    ALSO I HAVE BI- WIRE SPEAKERS CAN I CONNECT THEM TO MY AMP OR WILL IT CAUSE DAMAGE?
  2. namuk
    namuk
    Oct 23, 2006
    22,183
    +4,332
    IXOS 103 very good lead for sub. for your speakers you need BI-wire speaker cable. means four wires connect 2 to - and 2 too + on amp and the 2 -connect too speaker and the 2 + connect too speaker
