speaker cable
Mark.Yudkin
2.5mm stranded oxygen free copper.
mrbenn
use the search
MarkTaylor
Hi :hiya: what is the best type of cable to use with your speakers,i have the clip in type,cheers
Mark's answer above is probably still correct, but if you'd care to tell us which speakers you have and what they are connected to it will be easier to help you.
matt41
Also remember mains cable copper is 99.7 oxgen free. 1mm T and E makes a good cheap option a doess 2.5mm T&E if you wish.
You can pull through the Earth, or many years ago 1mm twin was available.
Knowing what is being connected to what would help matters though as mntioned above.
coppiceno1
Hi thanks for the info,i have a sony hi fi lbt - n 455,i'm replacing the standard speakers with sony colum speakers
scorpion88
Totally agreee with Mark (post 2):smashin:
