speaker cable
Discussion in 'Home Cinema Speakers' started by upallnight, Oct 28, 2003.
  1. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    what do you suggest as good speaker cable
    one that wont break the bank either
  2. davehk
    davehk
    Oct 17, 2003
    702
    28
    London
    +45
    Sommer Meridian 1.5mm £0.79/m
    Sommer Meridian 2.5mm £0.87/m
    Sommer Meridian 4.0mm £1.29/m if you want heavy stuff
    Sommer Meridian 6.0mm £1.59/m if you want really heavy stuff
    all exc VAT from Studiospares
  3. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    748
    16
    Derbyshire
    QED Silver Anniversery is always a good bet and works with virtual every budget to mid range system known to man. Its around £5 per meter or £8.50 for the biwire.
    If you've got a killer setup then maybe a look in the direction of the £20+ Atlas cables wouldn't go amiss.
  4. upallnight
    upallnight
    Jun 11, 2003
    1,683
    48
    watford
    +77
    this is looking favourite
    thanks for replying
  5. dml
    dml
    Finally got round to replacing the cables for the LCR on my system last night to QED Silver Anniversary. Had been using 14ga flat cable from Tandy/Radioshack.
    Obviously not a double blind test, but my impression was that the sound was clearer & brighter. No complaints.
