Speaker Cable Wanted
Mensy
Hi guys
Ive just bought 2 new speakers which i need speaker wire for im currently using
monster standard -standard 16 guage 1.3mm speaker wire with ez strip jacket i was ideally looking for the same speaker wire but carnt find it any where, im usless with speaker wire so dunno what im looking for lol can some one recommend one thats similar to that ? i dont want anything expensive and no name brands are fine. ]
All help is appreciated cheers :smashin:
Mensy
No one ? can someone point me in the right direction for cheap but good speaker cable then ?
push
What's your budget per metre?
Lots of us recommend Van Damme cables - specifically, the Studio Blue. The 2.5mm version can be had for 2.50 per metre. The 1.5mm version comes in at under 2 quid a metre.
Stretchy
Yep, van Damme all the way! Forum steered me toward it a few months ago after a frustrating QED evolution experience, very happy with it!
Nevaborn
Well Van Damme Blue is highly recommended however i am about to try some 532 strand cable off ebay thats about £1 a metre and see how that sounds.
Mensy
Let me know how it gets on mate :) i dont mind £1 a metre.
Nevaborn
Well it was about £1.15 a metre but what the hells £0.15p in this game lol
Im just tight with money and the cable looks good quality and at 532 strand 2x 4mm it just seemed such better value than bi name brands that give you less cable and more insulation.
Of course the lack of insulation is a concern but im not really in an environment that will give off significant interference. Im also of the band that copper is what you need and this in picture atleast looks like a big old lump of oxygen free copper so fingers crossed.
What i saved on the cable tho ive blown £20 of on som Sewell Silverback Kong banana plugs. Hope they do the business. Ill be sure to do a post when its all set up lol
Mensy
Thanx buddy, i just need something that will last and isnt thin as hair lol
Similar threads
