Speaker cable up a wall
Discussion in 'Home Cinema Speakers' started by magnatom, Jul 25, 2002.
  1. magnatom
    magnatom
    I am about to move a couple of my speakers (surrounds) and place them higher up on my walls.
    I am looking for some speaker cable (under £2.50/meter) that when flush with a wall isn't too obtrusive. Inserting them in the wall is not an option :(.
    I am not a believer in speaker cable hype (thus the maximum price) so long as the resistance is low enough to drive my Kef Eggs well enough.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Ixos do a flat cable with self adhesive backing that may do the trick. I think that it's reference is 607.
    I use it under carpets and up walls for my rears.
