Speaker cable thats ok with heat?
Discussion in 'Cables & Switches' started by coolamasta, Feb 21, 2013.
  1. coolamasta
    coolamasta
    Nov 22, 2011
    203
    Brizzol
    +30
    Hi Guys, quick random question, I am doing out my kitchen and have decided to fit some ceiling speakers and need to prepare the holes and run the cables before I get it re-plastered.
    I have a neat run along the ceiling between joists where I want to put the speakers but at the end of the kitchen I need to drop down some box section with the cables but the box section has radiator pipes in un-lagged!
    Will normal speaker cable be OK sat around high temps or should I run the speaker cables in something? I would lag the pipes but there is no space :thumbsdow
    Cheers for any help :)
  2. larkone
    larkone
    Apr 21, 2006
    4,270
    134
    North Essex
    +1,182
