Speaker Cable run going OUTSIDE!
Discussion in 'Cables & Switches' started by Jonmurgie, Aug 30, 2005.
  1. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
    I have resided myself that I will have to run some speaker cable OUTSIDE my house for the rear speakers in my setup.
    Now I don't want to spend £££ on cable but then again it will be a Yamaha 757 powering the Kef Q15 rears so didn't want anything that's going to be a waste of effort...
    Can anyone offer me some suggestins on cost effect wiring for these speakers? I'm NOT bi-wiring them BTW :)
    Jon
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Can you chase the cable into the wall?
    I believe the only issue will be the very long term stability of the cable outer...
    If its out of the sun, I would have thought any cable will be ok.
    Gareth
  3. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
    For the run to go inside I have a HUGE patio door and a fireplace to contend with... and it's Laminate flooring so no help there!!
    I was thinking of running the cable in a conduit casing to give it some external protection...
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I am sure it will be absolutly fine like that.
    Gareth.
  5. demostenes
    demostenes
    Hi jonmurgy,
    The best way to run cables (any cable) outside is inside a Semi Rigid Polyethylene Pipe or PVC like the ones used in electrical installations. U can use a rigid pipe but its not as resistant as the other 2.
    U can buy them at any electrical wharehouse and costs around 1£ /m
    Here's a link to a PT site: http://www.jsl-online.net/produtos/listsub.asp?Id=5
    (sorry dont know any English 1 :thumbsup: ):
  6. davee
    davee
    Jun 15, 2004
    717
    twickenham
    +57
    If you dont run the cable in conduit the squirrels mice and other creatures will soon eat through the casing :eek:
  7. Troon
    Troon
    Apr 28, 2005
    151
    Where it comes into the house put a little droop in the cable, so that condensation and rainwater drip off the bottom of the droop rather than seeping indoors.
  8. demostenes
    demostenes
    davee as pointed out a very important thing :smashin: We've had several problems with electrical cable that tends to attract hungry rats :thumbsdow.
    To add a thing to troon's post, u should isolate both ends of the tube as well (silicone will do fine).
    :thumbsup:
  9. Jonmurgie
    Jonmurgie
    Jun 6, 2004
    806
    Cheltenham, Glos
    +44
    no probs... thanks for the great advice...
    Now I'm having right dilemas choosing what cable to use... almost bought some QED Micro but then keep stumbling across threads about electircal cable and Cat5 cable!!
  10. Fatman
    Fatman
    Apr 4, 2004
    125
    16
    Could you use metal piping (e.g. copper?) as your external conduit?
