Speaker cable question?
Discussion in 'Cables & Switches' started by NumbNutz, Aug 17, 2005.
  1. NumbNutz
    NumbNutz
    Jan 12, 2004
    143
    Derbyshire
    +15
    I used to have a Panasonic 28in 4/3 TV with built in Dolby Pro Logic and two rear surround sound speakers. I had the speaker wires buried into the wall and under a bedroom floorboards so they came out of the ceiling where I wanted them. The Panasonic speakers that were attached had a rating of 8 ohms and 15W. Now the Panny TV has gone and so have the speakers.
    I've replaced the speakers with a Toshiba SD-44HK home cinema system. Now these speakers are rated at 8 ohms but 60W.
    The question is:
    Is it wise/safe to hook the speakers up using the Panasoic cables I already have built into the room?
    or ...
    Should I stop now and wait until I have had the Toshiba supplied cables put into the wall?
    I'm sorry if this is a stupid question but I wouldn't want to do something that isn't safe.
    Thanks in advance
    Andrew
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    you'll be fine, don't worry about it :)
