Speaker cable query
Discussion in 'AV Receivers & Amplifiers' started by PeterL, Jul 23, 2002.
  1. PeterL
    PeterL
    Apr 20, 2002
    112
    16
    Bournemouth
    Hi all
    I have a Yamaha HTR-5540RDS av amp which is part of an HTiB-45 package including 5 twin-coned satellites and a subwoofer.
    The speaker cable that came with the kit is extensive (15 metres for each of the rears), but also pretty thin.
    I have been thinking of buying some of Richer Sounds, Gale 99p per metre speaker cable, but would this make much difference? I know that at least to some degree it would, but would it make a significant difference to the sound output considering the fact that I am using satellites?
    Thanks for any help given.
    PeterL
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    PeterL,
    Personally, I would stick with the original.
    I have Naim NAC-5, QED Silver Anniversary Bi-Wire, and over the years various other strange brews.
    Without being condescending my feeling is that with what you have, you won't hear any difference.
    In all honesty, with what I have, I can't hear any difference.
