Speaker cable problem
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jezzialli, Feb 10, 2005.
  1. jezzialli
    jezzialli
    Feb 6, 2005
    4
    I have just purchased an NAD C352 amplifier and some QED SA speaker cable with QED Airloc plugs at each end. However, I can't seem to fit them into the cable sockets at the back of my amp. Should they fit, and has anyone else had this problem? Any suggestions over what I can do, bearing in mind I know next-to-nothing about Hi-Fi's?
    Thanks in advance for any help.
  2. Harryo
    Harryo
    Oct 11, 2004
    112
    Merseyside
    +6
    I assume that you have removed the small plastic caps that cover the end of the terminal posts?
    Once the plastic caps have been removed the Airlocs will just plug into the end of the amps speaker connectors.
    I have the same amp and I am using WBT connectors which fit fine.
    Harryo
  3. jezzialli
    jezzialli
    Feb 6, 2005
    4
    Ah right! I was unscrewing the knobs and trying to force the plugs down the hole that appears. I didn't realise they went into the end of the knobs themselves! Doh!
    Cheers!!
  4. Harryo
    Harryo
    Oct 11, 2004
    112
    Merseyside
    +6
    I only know from first-hand experience! :)
    At my first attempt to attach the speaker cables I tried what you did, it took a while for it to dawn on me that the little plastic caps had to be removed. :rolleyes:
    They can be fiddly to remove but they will detach.
    Cheers - Harryo
