Dylan555
Established Member
Hi, I’ve just bought some speaker cable, but there’s no way to tell which one’s positive and negative. I’m going to use name labels, put them on one end of a cable, and then one on the other end of the same cable. And then (it’s a black cable) connect black to black on the receiver and speakers, and white (name label) to red. Can I just leave the name label on? Or do I need to remove it?
Also, are both cables identical? Is one positive and the other negative, or are they both the same?
For example if I had a black and red cable, and connected black to red on the speakers and receiver, and red to black on the receiver and speakers, would this be ok, because they’re connected to the same colour on the speakers, or would this not be ok, because both cables are actually different?
Sorry for such a long question, I’m still quite new to all of this. Thanks.
