Speaker cable lengths/delays?
Discussion in 'Cables & Switches' started by probedb, Apr 30, 2005.
  1. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    Hi all,
    I've always made sure my left and right speakers have the same cable length, figuring it'll introduce miniscule delays if they're different.
    I've also made the centre speaker cable the same length.
    Does this actually matter anymore when running an AV amp? Since the delays are adjustable anyways, does it make a difference?
    Thanks in advance!
    Paul.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    It really doesn't matter unless you're using cable differences of tens of metres. Moving your head a couple centimetres to one side will make far more difference as sound travels much slower through air. :)
  3. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
    I think the theory being you need v big differences (I can't remember if it was in the hundred of metres or kilometers) before it comes close to what human hearing can pick up - so not something to worry about. FWIW, I've got a cable on my right speaker that's a couple of metres shorter than the left - I certainly can't hear any differnce...
    Jon
  4. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    OK thanks very much for clearing that up :) I can get rid of some redundant cable now.
  5. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Different lengths (unless ridiculous) will make no (Humanly) audible difference.
    It's always good to keep signal lengths as short as possible though. Theory here being the signal will degrade over distance. Again whether this is audible over a couple of metres is obviously negotiable....:)
