speaker cable length, same for each speaker?
Discussion in 'Home Cinema Speakers' started by shoestring25, Feb 10, 2003.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,831
    essex
    +409
    is it right that i should use the same length of speaker cable for the fronts, center and surounds? won't you end up with meters of cable for the fronts and center just coiled up that you don't need?
    if that is the case i will need 60m!!!!
    i have a budget of £150 for the speaker cable any sugestions for a suitable speaker cable for about £2.50 a meter?
    all advice and suggestions greatfully received
    cheers :confused:
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    In my opinion....
    Make sure front L & R are the same length as each other.
    Make sure rear L & R are the same length as each other.
    If you have three identical front speakers, make the center the same length as the front L & R, otherwise don't worry too much.
  3. sinister_stu
    sinister_stu
    Why?
    The signal travels so quickly down the cable that you would need 10km on one and 1m on the other to hear any difference. It really isn't that important.
  4. 50/50
    50/50
    Jan 5, 2003
    249
    16
    Nottingham
    IMO it doesnt make the slightest difference. Human ears cannot hear any time difference at such a short distance. Use as much as you need.
    It is near impossible to hear any lag at a distance like that difference.
    The only advantage of buying the same length wire is; if you are going to move to a another house or something.
    Im using CABLE TALK TALK 3.1 throughout. I am very happy with it. Its great value for money. Its isnt very fexible, so it isnt great for all situations.
    QED QUDOS ORIGINAL is worth considering, but I found abit light weight.
  5. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I suspect you wouldn't hear anything on the end of a 10Km cable...isn't this a load issue rather than timing? As long as you balance the sound output i wouldn't worry too much.
    For me, in the lounge, the cables are as long as they need to be to look right, in the hi-fi room all my cables are the same length and curled up here there and everywhere
    spence
  6. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    It's not down to timing though, it's down to the effect the cable has on the signal passing through it.
    This effect is probably not noticable in real-world situations, but then if you are spending a reasonable chunk on money on the cable in the first place, you want to make the most of it.
  7. shoestring25
    shoestring25
    Feb 2, 2003
    3,831
    essex
    +409
    surely every cable has electrical resistance and the longer the cable is the more resistance the signal has to pass through.
    how would this affect the signal? loss of definition and detail or sound volume?
    cheers
  8. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Reduced volume but these things are usually frequency dependent so it maybe more complexed than just a linear drop in dB. In normal circumstances i'd expect things like speaker position and room acoustics to affect the sound between different speakers to a greater degree than modest differences in cable length...with the proviso i'm no expert!
    spence
  9. NicolasB
    NicolasB
    Oct 3, 2002
    6,450
    Emily's Shop
    +898
  10. sinister_stu
    sinister_stu
    The resistance of the cable is so small that it really isn't issue unless in an extreme situation. I was exaggerating when I said you would need 10km:1m. Just making my point.
    Read the thread nicolasB suggests. It says everything I would say.
  11. shoestring25
    shoestring25
    Feb 2, 2003
    3,831
    essex
    +409
    The front speakers require 3-meter lengths and the rears 12-meter lengths so having the fronts and centres at shorter lengths would almost half the amount of cable needed and save me money. But would such a difference in length affect the sound.
    Barring in mind
    1) Good quality cable used not cheap rubbish
    2) Seating position at the rear of the room between the rear speakers
    3) If all speaker lengths are to be the same, 60m of cable needed in stead of 33m and extra would be coiled up behind speakers out of sight (any harm in coiling it up)
  12. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I've similar differences in cable length in the family room, and do not find it a problem...
    spence
  13. sinister_stu
    sinister_stu
    Using the lengths you have stated, I don't see a problem with having different lengths of cable. If I were in your position, I would go with the cheaper option of buying cable of different lengths.
    If you were to buy your cable all the same length then coiling the extra 9m on the fronts would probably have more of an effect on the sound than using shorter runs.
  14. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    All I have done is have same lengths for each pair
    rears use flat biwiring cable around skirting board then half to each speaker.
    Fronts use same length - what would happen if I moved the amp?
    Hence 2.5m for each front
  15. wookie
    wookie
    don't coil up the speaker wire as you will turn your nice speaker cable into a nice inductor:D This will have a far greater effect than unequal lengths.
    Fold spare cable up concertina style
  16. norbert
    norbert
    miller25
    I've nothing to add to the length of cable debate (FWIW I have mine the same length but it does means I have about 6 metres tied up on one as my left speaker sits next to my rack).
    However, if you're after decent speaker cable at a cheap price I'd have to recommend the DIY route. Have a search on this forum for 'ffrc'. I made this speaker cable about 6 months ago and found it a huge upgrade from my previous cable (QED Original MKII bi-wire cable at £5.00 per metre). The FFRC cable comes in at about 1.20 per metre if I remember correctly and was dead simple to make. Even if you go for the full 60 metres you'll still only spend half of your budget!
    I used to use Cable Talk 3.1 before upgrading to the QED and would say that that was easily my least favourite of the three.
    Regards
    Richard
  17. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    for properly designed cable different lengths in this application is fine, you will not hear any difference. It is irrelevant. The difference are minute and theoretical only, certainly not audible, not even close.
    Timing :( just inaccurate I am afraid.
