speaker cable help
Discussion in 'Cables & Switches' started by ttwarren, Sep 9, 2005.
  1. ttwarren
    ttwarren
    could do with some advice rear speaker and side speaker what would be the best cable to use without spending silly money i am using denon av amp and mission 77ds side and rear speakers sides will be 8 metres each and rears 11 meters approx so 38 meters a lot of cable . would guess most expensive cable on the front speakers was thinking chord carnival bi wire to mission 773 floorstanders and to b&w centre am i correct in my thinking does anyone know what monster speaker cable is like ebay 100 feet for £40.00 was thinking may be suitable for sides and rear or am i wasting my money . any help would be great thanks
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Wasting your money. Some of the best stuff around is from Maplins Van Damme cable or there are several DIY options. Cat5 being one of them though 40 metres of braiding may have you thinking that it's not worth the hassle. Run a search on the cable forum it will pull up all sorts of interesting debates.....
  3. ttwarren
    ttwarren
    hi is the cable (via maplins) the profesional speaker cable £113 for 50 meters if so i will take your advice and get that do you have any recomendations for the fronts or is the chord fine thanks again
  4. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    You can use exactly the same for the fronts. Are you BI AMping or is a single run?
  5. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    The speaker cable from Maplins that I know is exceptionally good for the money is not £113/50m it is £12.99 for 20m which equates to a lot less.
    The cable I've used/tried does not look like a current item anymore but they are doing a higher current rating version now. See here.... Speaker cable
  6. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Haven't tried that. Not convinced you'd have sufficient surface area of cable. You can't really see by the picture and there's no info that I can see. What's the AWG of the cable?
  7. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    The cable I am using (well actually I'm not) runs a Krell KAV300 amp which is 150 watts/channel. It uses 79 strand wire. The code is N15AP. Actually just looking at the specs of the link it looks the same as it is a white sheath with a polarity stripe as mine.
    79/0.2 strand wire.
    This IMHO gets real close to Nordost Blue heaven, some would say there's no difference depending on your line of thought.
  8. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    I can easily believe it.
    If it' does a good job and costs peanuts then that's the way to go.
  9. showcase
    showcase
    hi sorry if this is covered before, i have asked before which cables i should go for, and was recommened either van dam.... or cat5, i have looked around, so if this is a stupid question, if i purchase cat5 cable do i just cut of the ends (the plastic bits) and the use the wire to wire the speaker to the amp????
    cheers
  10. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    There is a fairly simple step by step guide in the link in my signature.
    This is one variation which works well.
  11. showcase
    showcase
    hey great link and good idea, do u have to use 3 cables??? to get a superb sound........ the cables looks like a think rope (when finished)!! how are u suppoes to hide it? cannot exactly put it under the carpet :rotfl: , peeps might think its a dead mice or somthing, not that we have mice in the house :rolleyes: , taking it up a wall to the rear speakers.....
    any other suggestions?? i might try it.. it the thinkness of the cable thats putting me off
    cheers anyway
  12. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Don't have to braid it. I've known at least one person who hasn't and said it's still very good. Just run the 3 lengths of cable (Or more - I found six to be the magic number)
  13. showcase
    showcase
    hmmm :rotfl: 6 cables???? for one speaker?????? or i'm i getting all this wrong, sorry i am just looking at cables to purchase.
    do u hide the cables? and where and how? :)
    cheers again
  14. guli
    guli
    Sep 3, 2004
    412
    16
    Knightshade,
    Your guide has helped guide me to the world of Cat5.
    Would you happen to have the link to the 6 cable braid handy? I know it's somewhere on this forum and doing a search would be advisable, but if you could post the link to the set-up, I would be very grateful.
    Thanks!
    Alex
  15. Troon
    Troon
    Apr 28, 2005
    151
    Just use 79-strand. I don't believe you'll tell the difference, and the cat5 route looks like a hassle for no benefit.
  16. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Good site for 6 cable braid and other CTA-5 stuff is http://www.tnt-audio.com/clinica/spkcbl_e.html
    And, it really is easy. Answer to question about how you hide it is ... in the wall (ok, not very useful for everyone, but worked great for me)
    Greg
