Witterings
I'm currently using this which I bought a reel of several years ago but have just upgraded my speakers
www.gjelectronics.co.uk
Will I notice any difference by going to say QED Classic 42 ... OR ... 79 Strand and again what difference might I notice between the 42 and the 79 as the 42 will be "easier to lose" where it's got to run in the crevice of a window sill.
Also is here any advantage to buying custom lengths with banana plugs fitted as opposed to me just using some of these .... in fact is there any advantage to plugs at all or might you just as well use the wire straight into the speaker?
Amazon product
If there was any advantage to soldering alternative plugs on I'd be happy to do that myself but would need pointing in the right direction what to get?
Alternative suggestions for speaker wire also appreciated, don't mind spending more than the QED but only if it'll make a noticeable difference, one stipulation it must be available in white.
Samson - 2 x 42 Strand loudspeaker cable, black, ribbed polarity - 100m — GJ Electronics
Amazon product
