Speaker cable Gauge
Discussion in 'Cables & Switches' started by demostenes, Aug 22, 2005.
  1. demostenes
    demostenes
    Hi All :hiya:
    I've installed about 10m of 1,5mm2 speeker cable for the back surround speakers (KEF eggs powered by a panny 100W /channel) because i had a difficult time running 2.5mm2 (which is widely recomended :smashin: ) through a 16mm tube inside the wall.
    My question is:
    Should i stick to the 1.5mm2 to the front+central speakers (2m long) or could i use 2.5mm2?
    Another thing... can i install the back KEF eggs on the cealing using the holes in their feet :rolleyes: ?
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
