Speaker cable for sub line-in?
Discussion in 'Home Cinema Buying & Building' started by helvetica, Jul 8, 2015.
  1. helvetica
    helvetica
    Oct 6, 2009
    99
    11
    +5
    Hi, my electrician used twin speaker cable instead of subwoofer phono (RCA) cable. He reckons he can solder a phono head to the speaker cable and it will be the same , but I read that sub cable should be shielded. Can anyone advise?
    The speaker cable isn't in trunking so I am stuck with it.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    The shielding is only needed if you are running power cables and/or other cables very close to the sub cable. If not then should be fine. Since you are stuck with the cable now you may as well try it and see how it sounds.
  3. helvetica
    helvetica
    Oct 6, 2009
    99
    11
    +5
    the sub itself is powered (mordant short 308), does this count? The speaker cable would pass the power cable, but only at the point of entry into the room.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    That should be fine it is long runs in parallel would be the concern.
