speaker cable for MA silver series
Discussion in 'Cables & Switches' started by lubej, Feb 2, 2009.
  1. lubej
    lubej
    Dec 12, 2006
    93
    +4
    Hello
    What speaker cables do you recommend for MA silver range.
    This speakers are on the bright side so I thing warm, neutral cables will be needed.
    What do you think?
    Thank you.
  2. lubej
    lubej
    Dec 12, 2006
    93
    +4
    Anyone?
    Can you tell me few "warm, laid back" cables.
    Or words such as warm, neutral, laid back, bright, detailed.... cables are only a myth and all speaker cables are the same, that means the difference is very small and it can't be noticed.
    Thank you.
  3. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    There are exceptions of course, but a lot of views around here are based on 'enough copper' or 'not enough copper' beyond that you are using words that many of us would not try to apply to speaker cables.
    How long will your cables be btw?
  4. Dankeech
    Dankeech
    Feb 1, 2005
    3,637
    Stevenage, Herts
    +299
    Also, what amplifier are you using with the speakers?
    I also recommend copper-based wiring if you're finding the sound a little shrill.
    Dan.
  5. lubej
    lubej
    Dec 12, 2006
    93
    +4
    Thank you, I did not decide on the receiver yet, but I will most probably buy onkyo 876 or yamaha 1900.
    Distance will be 4, 5 meters for fronts and arround 10 m for rear speakers.
    What do you think regarading qed silver aniverssary xt cable ? Is it good match with MA?
    Thank you.
    br
  6. lubej
    lubej
    Dec 12, 2006
    93
    +4
  7. lubej
    lubej
    Dec 12, 2006
    93
    +4
    Hello
    What do you think about vdh clearwater?
