Speaker cable extending
Discussion in 'Home Cinema Speakers' started by Greg Hook, Aug 17, 2003.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,415
    2
    In a secret location with Jennifer Lawrence
    +9,111
    The wire to my two rear surrounds speakers is not quite long enough.
    Would there be much loss of quality if I just joined another bit of (identical) wire to it?
    Or would I need to replace the whole length?
    I have QED wires.
    Greg
  2. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    Done it with qed silver cable. I know they say dont, but i can't tell the difference. Done it on my fronts, and i just can't tell (though they are for two channle) Even harder to tell with rears i bet
    But thats just me
  3. Dazed
    Dazed
    I've just done it with my 2nd zone speakers (in my kitchen) - after moving my whole system around. It seems to work perfectly well and I'm sure any quality drop won't be that noticeable with surrounds.
    Best bet is to get one of those plastic connector block thingys - not sure what the proper name is - it's got a hole either side to feed in the wires and screws to hold them down. That's what I did anyway - just for the sack of neatness
  4. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,415
    2
    +9,111
    OK thats sorted then.
    Thanks for the replies.
    Greg
