Speaker cable dividers?
Discussion in 'AV Receivers & Amplifiers' started by mevetts, Aug 23, 2004.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    Mods feel free to move, but was not too sure where to post this question?
    I have a hi-fi which I currently use to feed sound from my DVD player through. However, is it possible to have the speakers connected to both my hi-fi and receiver via some form of speaker cable divider?
    Obviously, I would not use both my hi-fi and receiver at the same time!
    Can this be done?
    Any advice or suggestions would be greatfully received.
    Thanks,
    Mark.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    I think you can get a switch unit comparator? used by the "trade" for demoing 2 different amps on a single pair of speakers, no idea on cost or use high current mains switches (tripoles?)
  3. bobbypunk
    bobbypunk
    QED used to do a switch box to allow exactly this, they still do a wallmount version,
    check www.qed.co.uk.
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks for the link and it is exactly what I'm after (the MA19) :clap: , but it says that they are discontinuing the stock :thumbsdow (http://www.qed.co.uk/acc/acc.html) and there are no prices :rolleyes: .
    Does anyone know where I can get the same type of product?
    Cheers,
    Mark.
  5. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,538
    Near London.
    +208
    Electrical suppliers like CPC and Maplin usually stock them, although they're technically not of audiophile quality I don't think it would make a difference as you're adding a switch into the line anyway.
  7. mevetts
    mevetts
    Oct 31, 2003
    439
    Eviljohn2, I agree that it is not a recommended set-up, but it is only going to be a temporary solution for a few months until I can purchase the Cantons :) .
    The ebay link looks just the job, thanks. Will keep my eye on it over the next few days.
    I can not seem to find too many online suppliers though.
    Cheers,
    Mark.
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,538
    Near London.
    +208
  9. mevetts
    mevetts
    Oct 31, 2003
    439
    Looks just the ticket, cheers eviljohn2.
