Speaker cable - DAV-SC8
Discussion in 'Home Cinema Buying & Building' started by simonph, May 14, 2004.
  1. simonph
    simonph
    May 21, 2002
    94
    Am having a laminate floor laid on Monday and was wondering about laying speaker cable down before this happens. Just been into Superfi and they told me there isn't any speaker cable that will fit into the speakers that normally come with a system like the DAV-SC8.. Is this true? The cable that usually comes in the box just looks like ordinary cheap stuff you could pick up for 20p a metre! :confused:
  2. bobbypunk
    bobbypunk
    there is a special connection on the sony DAVSC systems but also somebody told me you can take these terminations off and connect then to new speaker cable allowing you to use higher quality thin guage cables like the QED micro cable!!
