speaker cable/copper mains flex
Discussion in 'Cables & Switches' started by sean.pittaway, Oct 6, 2004.
  1. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    I am having my house re-wrired in a week or two, so while its in a state i wanted to get my HC speakers wired in at the same time...
    When i was a bit younger i used the thick coper mains flex for my speaker cable, using this now would obvoiusly save quite a few quid over didicated speaker cable :)
    You want see it because its sank into the wall so that not a problem, but what does it sound like, can you really tell much of a differance over decent cable?
    Cheers, Sean.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I doubt that there will be an audible difference and thus would chose the cheaper cable with the same (or greater) cross-section.
