Speaker cable connection advice...not that simple a question!!
Discussion in 'Cables & Switches' started by Stinky985, Oct 27, 2005.
  1. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    HI - I have bought some IXOS Gamma cable that is 4.2mm thick. Banana plugs can normally take a width of 4mm, as can spades by the look of it!
    So my question is, how should i connect the cables to my Yamaha RXV1500 and AE Aegis Evo's? i used to use banana plugs but obviously cant seem to now! Bearing in mind that the kit is quite decent, i'd like the best possible connection with what i have!
    Is there any advantage banana/spades have over bare wires into binding posts?(or is that a question i shouldnt be asking! :rolleyes:)
    Any advice appreciated as i need to get set up this weekend!
  2. loadsofleads
    loadsofleads
    Hi Stinky, Supras new CombiCon banana or spade connectors will take cable diameter up to 6mm, but they aren't cheap.
    As for any 'advantage', most banana and spades are there for convenience more than anything else, there are a few exceptions such as QED's 'airloc' banana plugs that seal the bear wire from the harmful effects of Oxygen on copper, but they ain't cheap either :rolleyes:
  3. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
  4. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    Haven't used them, but they look good quality and reasonable price.
    You could also use something like these and leave the sleeves off, covering the ternnination with some heat shrink sleeving instead.
  5. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    those shark things look ok but say cables upto 4mm. would they take the 4.2mm if i used heat shrink on them? I guess they would need soldering? the cable by the way is IXOX 6006 gamma or whatever its called now!
  6. Peridot
    Peridot
    Aug 24, 2004
    2,995
    +293
    I assume the 4.2mm is the outer diameter of the cable?
    The inner conductors will fit the plug okay but yes, it would be best to solder them. :)
  7. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    4.2m i think the ixos site says: "4.2mm PC-OFC conductor" so i guess that means the actual copper. looks like i'll be testing my soldering skills then!!
  8. CJROSS
    CJROSS
    Nov 16, 2000
    5,105
    +343
    http://www.satcure.co.uk/accs/page13.htm
    Gold 4mm Banana Plug with 7mm (0.25") cable hole at side. Knurled securing screw. Code B008 Gold 4mm Banana Plug pair £2.10 - £8.40 for 4 pairs. Excellent banana plugs.
  9. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    they look like they could do the job - do you use them?! Certainly priced attractively!
