Speaker Cable Coding
Discussion in 'Home Cinema Speakers' started by Kera, Jan 5, 2004.
  1. Kera
    Kera
    I have a pair of speakers with an integral cable. Both are black, but one has a white line along it. I wish to fit an RCA coaxial connector so that I can use them with a digital TV tuner as they were originally just stripped wires and would like to know which cable goes to the centre pole and which goes to the shield ring?
    Please can someone help,
    Thanks.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I don't think there is a rule/standard for the color coding of such systems, so the manufacturer may have choosen whatever he liked at the time.
    It doesn't matter though as long as you solder both speaker (cables) in the same manner, i.e. both wires with the white line on the center pole or both on the shield ring.
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Connect a 1.5V battery between the wires.
    If the speaker cone moves out you have connected correctly - i.e. +ve to +ve, -ve to -ve.
    If the speaker cone moves in, the connections are reversed.
    I've never tried this so can't confirm whether it works and I presume it won't damage the speaker...
  4. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    The way I always do it (personnaly) is that one cable normally has a line/raised line on it, this for me is ALWAYS - (Negative) / black / ground, whatever you prefer to call it.
