Apologies in advance if this question has been asked many times already!
I'm moving my hifi set up upstairs into a much smaller room, however the placement of my speakers is along a different wall to the amp / turntable so I actually need much longer cable. Also replacing the speakers for some "smaller" sized options.
I currently have Chord Rumour 2 cable - its very old but still in very good condition also its silver plated wire.
I have purchased a pair of B&W 606 S2's, and got £50 towards speaker cable. They recommended QED XT25 pre terminated 5m length copper cable. Copper being a good choice to tame the high treble from the 606's. From what I understand the XT25 is a fairly basic / low budget option. It also looks like 5m is a little short for one side, I need another 50cm or so.
I presume both left and right speakers should be wired with exact same length of cable? or is a small variation ok - 6m on one side and 5m on other? also I feel like at 6m the lengths are very long, do need thicker cable to cope with this or is something like the XT25 fine?
What cable would you guys recommend for a pair of copper 6m cables? My speakers are 606 S2, amp is a Cambridge CXA60.
Thanks in advance
Thanks in advance
