steelydanfan
Hi all, could anyone recommend a good quality speaker cable in the up to £2.50 a metre range please?
I am specifically looking for something that is fairly flexible for tight/restricted spaces.
It's for a surround set up in my "man-cave"
consisting of a gaming pc and a PS3, I have rescued some old gear from my loft, I probably should have sold this lot while it had some value but then I wouldn't have been able to set this up if I had
I am using a Yamaha DSP-A630SE with a Mirage AVS-500 speaker set and a FRX-8 sub., the problem is my speaker cable is too stiff!
It is QED silver anniversary cable that I have had for several years which I also use on my main system in the living room, in the living room there is plenty of room around the speakers and amp so the stiff cable isn't a problem.
In my man-cave (study) there is not much room to get the cables onto the speakers and I don't want to forcibly bend the cable!
I see the Van Damme speaker cable gets regularly recommended on this forum but that also (from the pictures at least) looks fairly heavy duty and possibly inflexible?
Many thanks.
Many thanks.
