Speaker Cable Advice Needed
Discussion in 'Cables & Switches' started by MundoKev, Jun 25, 2004.
  1. MundoKev
    MundoKev
    Having only just discovered that a good quaility speaker cable might improve the sound on my cinema surround system I have a couple of questions
    As the supplied wire was just a bog standard affair, I am looking to get something a bit better without it costing me the earth
    I have been reading some of the articles and was mesmerised by some of the terminology
    For example "skin effect" what is that all about (no please don't tell me)
    All I am looking for is a cheap upgrade to the wiring for a noticeable difference in the sound quaility if possible
    I have found the item below and it LOOKS OK, but as a newbie, I could be wrong
    Any advice would be appreciated (please keep it simple)
    Superior Quality Speaker/Audio cable (sold by the metre)
    This cable is from my high quality audio range
    Details:
    1)Quality Figure of 8 Audio Cable
    2) Oxygen Free (OFC) bare copper stranded conductors
    3) 99.999% pure copper strands
    4) Very flexible transparent PVC jacket
    5) Suitable for HI-FI, Home or Car Stereo Systems
    Technical Data:
    Conductors - 2x2.2mm
    Inner Conductors - 196 x 0.12 mm (28/7/0.12mm)
    Outer Diameter - 2 x 4.0 mm
    Available by the metre
    Please order by the metre at 99p per metre, postal charges are included in this price.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    At that price it migth be worth buying enough to setup your front l/r speakers with it and to a subjective listening test after giving it a few hours to burn-in. Ie just leave your system playing something on repeat for a 2-3 hours or more say over night or when you are out. You may have found yourself a bargain. Good Old EBAY ;) I would try this though as I am sure there are a few people on here using it. :D
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32833&item=5705574929&rd=1
    I use QED Silver Anniversary but its not cheap at approx.£5 a metre:eek:
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    MundoKev what kit are you using?
  4. MundoKev
    MundoKev
    Using the Eltax Nova all in one system
    I also have a Videologic DTS system, but have not got around to installing it yet
    Just seen these also on ebay, any ideas which is the better quality option
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=32833&item=5706626355&rd=1
    This is the link to the first item
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14932&item=5705316667&rd=1
    And another
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14932&item=5705016187&rd=1
    It's just that the cable that came with my kit seems quite thin, and I need to make sure I am not just buying more of the same
    Thanks for the help
  5. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Dont think that thick cable =quality because that a good trap to fall into. I would still say the Ixos cable i found would be better than the no name stuff. In the end its your money and ears.
