willp2003
Established Member
I'm after a bit of advice for my first 5.1 set up please. I'm getting some Kef T speakers and probably a Yamaha V673 amp, but routing the rear cables will involve going round the fireplace in some D line trunking.
I'll need to run 2 speaker cables for the rears and also another 2 for my kitchen speakers (Q Acoustics 1010) and an ethernet cable.
The fireplace run will involve some 90 degree angles so I need a cable flexible enough and small enough to run through the trunking and get round the corners. The trunking would be the 22mm quarter circle stuff.
I know the van damme blue cables are well liked here, but they look quite chunky? Would the QED original cable be a good choice?
Cable length would be approx 6 - 8m to the rears and 10-12m to the kitchen. Willing to spend up to £2.50 per metre.
Edit: bugger, the trunking won't fit where i was going to run it, back to the drawing board. Might just have to have some ugly cables runs for now.
