speaker cable 10mm (8 AWG)
Discussion in 'Cables & Switches' started by Roguey, Nov 30, 2004.
  1. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    hi, i have some KEF Q7's (8 ohm speakers) + Q9c and also just found some 10mm (8 AWG) cable - enough for all the speakers, It is also tri-rated too. Would this be a good cable to use on the speakers? or would it be wrose?
    many thanks
    - Lee
  2. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    anyone know? should i use normal speaker cable (315 cores) or 10mm (8 AWG) eletrcial cable?
  3. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Hi Roguey,
    I'd certainly give it a go. You certainly won't do your system any harm. You may well find it superior to 'proper speaker cable'.
    I use CAT5e myself but a lot of people use heavy gauge electrical cable and get very good results.
    Knight
  4. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    I've used 8AWG (I.C.E) cable before for speaker cable and it worked really well. The only down side is 2 runs of chunky cable to each speaker is not the easiest thing in the world to route nicely.
  5. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    ah thanks for the replies - so do you think its worth putting it to the front speakers as well - or just to the rears? and use my 'proper' speaker cable for the front?
    many thanks
  6. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    ps. as for the cables - they are being put inside the walls, so they never be seen
  7. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    I would use it for the fronts as well.
