Speaker Cabinet Repair Query
Discussion in 'Home Cinema Speakers' started by 4K UHD Fan, Sep 6, 2004.
  1. 4K UHD Fan
    4K UHD Fan
    Sep 8, 2002
    514
    43
    London
    +131
    Does anyone know of any products you can buy which would allow MDF based speakers to be resurfaced like new. I have 2 M&K THX Speakers (1 Front & 1 Rear) which both sustained case damage after falling from their brackets @ different times and now have either minor dents or case scratches. The speakers still work perfectly though.
    I just wonder if their is any alternative to shipping them back to M&K in the US as they have told me it will cost a lot more for the actual shipping than repairs so am looking for a UK alternative to this.
    The official M&K UK Importer do not seem very interested in assisting me in this matter so I will not be buying anything from them ever again!
    TIA
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    HomePC Nut
    Whenever we've had customers with a damaged cabinet (wood or MDF with wood veneer) - its usually a trip to our local French polisher and a few days later the spks come back good as new.
    Stripping a cabinet down to fully re-veneer would be costly and potentially you might not get them back together as well as the factory initially assembled them.
    Best regards
    Joe
  3. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    I would go along with the French Polisher to repair it. One of my speakers has a large ding in one top corner and it's away for repair at the moment. It does help that I'm quite friendly with a French Polisher through my work. I don't have a clue how much it would normally cost but he's only asking for a couple of beers :)
    Hope he does a good job as I've never used a French Polisher before.
  4. stellaman
    stellaman
    french polishing is not hard to do, look it up and have a go. its more about repetative patience than skill, you will want to french polish every bit of wood you see once you have done one piece. liberon do simple to use products.
