Speaker Brackets
Discussion in 'Home Cinema Speakers' started by ashboudj, May 4, 2001.
  1. ashboudj
    ashboudj
    Can anyone help me locate some decent speaker brackets for a set of Mission 6 Pack speakers.
    I am looking for something that will bolt into the two holes in the rear of the case and that is fairly discrete when looking at them from the front. Also some movement would be nice.
    I'm not really into the Argos, clamp them on a tray type bracket.
    Dave
  2. Berno
    Berno
    Feb 28, 2001
    43
    North West England
  3. ashboudj
    ashboudj
    Excellent, thanks very much. Not too bad on price either.
    Dave
