speaker ajustment Pionner Ax10i
Discussion in 'AV Receivers & Amplifiers' started by steve k, Jun 12, 2004.
  1. steve k
    steve k
    Apr 15, 2001
    703
    Birmingham
    +53
    Hi pep's
    Can someone tell me how to ajust the surrond speaker setting on the AX10i.
    The reason for askin is have not got the manual for the amp yet, :mad: was missing out of the box and not arrived from Pio yet. :eek:
    Have done a auto cal but want to tweek the setting , also can i save the first setting before i start tweeking so i can revert back.
    Also what is the best setting to set the amp to when watching sky, have not got a sub yet so only have 5 speaker set up, front speakers are set to large.
    Any help welcome :smashin:
  2. derekduvalle
    derekduvalle
  3. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    try going to pioneers site,i think you can download manual in pdf format,could be wrong but worth a look
  4. ancientgeek
    ancientgeek
    If you've got good quality front speakers, my preference is using the "direct" setting for normal 2-channel sound from Sky, and digital out from the Sky box to bypass the digibox D/A converters. (if your digibox has it)
