Speaker Advice
Discussion in 'Home Cinema Speakers' started by r2bmb, Apr 23, 2002.
  1. r2bmb
    r2bmb
    i am in the process of purchasing a Home cinema system.
    I have chosen the Yamaha DSP-AXP620 amplifier any other recommendations would be welcome.
    I am a little confused on the speakers.
    I have around £400-500 to spend on speaker's possibly more..!
    on 2 fronts 2 rears a centre and a sub..!
    Current Hardware:
    TV - Philips 28PW6332
    VCR - Philips VR-605
    DVD - Yamaha DVD-S796
    Digital Sky box
    Do you have any recommendations please..?
    Many thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Most people will recommend that you don't buy a cheap sub as they are worse than no sub at all but Richer Sounds do a range of Paradigm subs that start at £150 and forum members say that offer good value for money.
    Sound & Vision in Bolton are selling the Acoustic Energy AE1 set of two floorstanders, two bookshelf and a centre speaker for £299.
    Mission also do a home cinema speaker setup at a competitive price if you look around.
    Another alternative is to buy second hand and there are a few bargains to be had in the classified section of this forum. Buying second hand normally means that you can buy equipment of higher quality for your budget than buying new.
  3. Guest
    I've just bought a REL 150. Apart from the humming and buzzing (which you dont hear in action films), its not that bad. I highly recomend it...
    Homy
  4. r2bmb
    r2bmb
    Thanks for your comments
    I have found the following What do you think:
    Denon SCAVF100 NXT Home Cinema Package £ 370.00
    MISSION CINEMA M72 AV SPEAKER PACKAGE £340.00
    MISSION FS2AV NXT SPEAKER PACKAGE £ 450.00
    or a mixture of
    KEF CRESTA 3 SPEAKERS £150.00
    KEF CRESTA 2 SPEAKERS £100.00
    KEF CRESTA CENTRE SPEAKER £70
    Not sure on Sub though
  5. smallman28
    smallman28
  6. r2bmb
    r2bmb
    Many thanks for your advice i have now made the purchase
    over the over the weekend..!
    I got the following:
    Yamaha DSPAX620
    KEF Cresta 3
    KEF Cresta 2
    KEF PSW1000
    KEF CrestaC
    It sounds wicked..!
