Speaker advice for technics SA da8
Starbase804
Hi all, just been looking through old boxes and found my Technics SA DA8 amp that I bought new and used for my surround setup back in the day. I loved the sound but I'm no audiophile, what I'd like to know is what speakers would work well with this for a nice audio setup now, Amazon music streaming or similar. Is bi worth it? Don't want to spend a fortune, just some budget friendly options that will pair nicely with this amp.
ShanePJ
AVForums Sponsor
Are you looking at using the Technics for surround sound or just stereo? Will you want bookshelfs or floorstands as the main front to?
So long as you understand it's not up to the job feature wise as some of the latest AV Receivers there is no reason why this cannot be brought back to life
If your going down the simple bookshelf 5.1 solution, then something like the Wharfedale Diamond 9.1 speaker package could be a cheap option to bring the Technics back to life without breaking the budget. If you just want a simple stereo bookshelf we have loads of them available with some of the popular budget ones by Wharfedale, Mission or Q Acoustics. You might want to add a subwoofer to bring some bass to the room with the bookshelfs though. For floorstands, you could look at an array of options which will suit your budget
Your Technics can work with much better products than listed, but as you have mentioned about price, I've tried to keep it realistic, but if you do have a more healthy budget available, then I'm sure you can look at getting something more inline with the SA-DA8
Starbase804
I think mainly music playback, but I have found my Jamo center 100 that I used to use with it and I think I can see a Jamo sub in the loft but have to move some stuff, I have a feeling the sub had a broken spring clip, it was a pass through sub.
Floor standing would suit my position better. It's going in a garden room I built I few years ago that the whole back opens up onto a decked garden, 4m opening. Be nice to open up and have music in the summer rather than my megaboom speaker. So the ability to move the floor standing units either side of the opening would be nice, surround would be nice but definitely a nice to have rather than priority.
ShanePJ
AVForums Sponsor
As you've already got Jamo, the right suggestion should be to stay with Jamo and something like the S 805 might be a good starting point for you as it will enable you to keep the same family sound across the front end although depending upon how many years old they are, you might find they sound nothing like each other due to the evolution of the speakers over those years.
If you want to move to some sweater speakers that are more inline with the av receiver, you could jump to Q Acoustics Q3050i which I feel will be a good match enabling you to still find a matching centre and surrounds if you wish to do so
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
