Speaker A/B Test Switch
sjackson
Has anyone experience with speaker switches for A/B testing?
So a single amplifier into a box that feeds two sets of speakers. Some sort of switch that controls which set of speakers are being used.
Basically I want to live test two sets of speakers to see which I prefer without having to reconnect speakers cables. My amp doesn't have Sp1/Sp2 outputs.
Any recommendations for such a device?
Orobas
You will want something like a Beresford TC-7220 for that .. @Ugg10 will know the right box for sure so i have tagged him with this comment
3rdignis
Hear Here
I bought the Beresford TC-7220 for speaker comparisons, but equally good for amplifier comparisons - even cable comparisions. The important feature of this unit is that it "breaks before it makes" so no danger of connecting 2 amplifiers together in error. Peter
Khazul
One issue to consider - if A/B the speakers then this still will not be a true A/B as they will not be in exactly the same place so even two pairs of identical speakers may sound slightly different in a room.
Kapkirk
You can mitigate this effect slightly by having both pairs staggered, ie; 1 on the inside, 1 on the outside instead of having 2 on outside and 2 on inside.
Hear Here
Easily got round by doing tests in 2 parts - Pair 1 in "optimal" position and the other pair outside or inside (or one inside and the other outsise) - then switch with Pair 2 in prime position.
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
