Spdif
Discussion in 'Hi-Fi Stereo Systems & Separates' started by dragon1, Jun 9, 2003.
  1. dragon1
    dragon1
    Hi folks, I appologise if this is not the right place for this question, however, I am in the process of putting together a HC, driven from my PC, the motherboard has a line out jack socket ( 3.5mm) that can be configured to SPDIF.
    My Denon amp has both optical and coax sockets on it ( strangely no 3.5mm sockets)
    Is there a device or a box that will allow me to convert the 3.5mm output to either optical or coax and use the SPDIF ??
    I know to you experts this will sound either straight forward or completely stupid but to me its a bit confusing !!
    Many thanks
    Andy
  2. Free
    Free
    What i think you need is one of These and a digital coaxial cable.
  3. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    He is indeed correct, this is exactly what I do. Works a treat.
  4. dragon1
    dragon1
    Thanks guys, simple when you know how.
    andy
  5. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    or you can get the same effect by using a 3.5mm to 2 phono lead and just using the left socket.
  6. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Works for me :)
  7. paiger
    paiger
    Although this will use the DACs in your sound card, which is fine if they are good. Using the spdif output should take the digital bitstream straight to your amp for conversion.
    Worth thinking about. I'm going the spdif route as I suspect I'll get a better sound.
  8. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    I have my Videologic Sonicfury hooked into my DAC. Simply no comparison, using an external DAC in my case sounds FAR better...
