D
dandan4274
Hi all,
Been building up my HTPC, and it's almost done. Whilst I'm deciding what PVR s/ware to use, we're using the Hauppauge-supplied wintv2000.
This works fine apart from a really annoying sound issue. Basically, whenever a program goes into the adverts, (and subsequently in between each individual advert), there is a quite loud pop or crackle coinciding with the screen going black (between scenes if you like)
I'm at a complete loss as to what the problem is - anyone got any ideas ?
thanks
Danny
thanks
Danny
