SPDIF out on Sound Blaster Live Player 5.1
Discussion in 'Computer Components' started by Orbital, Sep 21, 2001.
  1. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Hi All,
    I've just got my 3.5mm jack to RCA connector to plug into my Sound Blaster Live but I can't get Dolby Digital signal to my amp <img src="confused.gif" border="0"> I've enabled SPDIF out within PowerDVD but the only feed the amp seems to get is a Pro Logic one. Do I need to enable it at a system level somewhere? (I'm running W98 SE). Any help would be much appreciated.
    Orbital
    PS I have tried doing a search for the above problem but it keeps screwing up for some reason! <img src="frown.gif" border="0"> Anybody else getting this using the search facility or is it just me?
  2. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    Hi, i'm not sure but i think you have to use a stereo 3.5mm jackplug to two phonos(red/white) etc. One lead (red or white) then gives PCM the other Dolby Digital/DTS etc.<br />Make sure the SPDIF is enabled in both Soundblasters software(sound setup) as well as PowerDVD.
  3. MattB
    MattB
    May 17, 2001
    189
    Essex,UK
    To get DD5.1 SPDIF out use a mono phono-3.5mm jack cable (or phono-phono RG59 and phono-jack converter as I do) connected to the yellow jack.
    When I got my SBlive1024 nearly 2 years ago, DD5.1 was not supported but I enabled it using DVD Genie (search Google) a great little program that lets you fool around with all kinds of stuff.
    Finally, I have seen a post somewhere stating that the SBlive SPDIF output is logic level not 75 ohm. This may well be true, I have not got round to checking, but my processor is happy with the yellow output.
    Good luck,
  4. Orbital
    Orbital
    Apr 20, 2001
    512
    Midlands
    +4
    Right that's that sorted. Lovely Dolby Digital is with me once more <img src="biggrin.gif" border="0"> I hadn't de-selected the AC3 decoding in the Soundblaster Setting's, so it was feeding my amp an already decoded stream! Silly me <img src="graemlins/clown.gif" border="0" alt="[Clown]" />
    I have another problem though which is this. Whenever I click on one of the buttons on the menu part of a film, say to select a particular scene I get funny clicking noise which is really annoying. Has anyone else had this problem or know of it?
    Dave
