Question SPDIF iPurifier + Remedy Reclocker Work Together OK?
Discussion in 'Music Streamers' started by malcolmduffin, Oct 20, 2017.
Tags:
  1. malcolmduffin
    malcolmduffin
    Apr 30, 2017
    82
    11
    Manchester UK
    +15
    Hello everyone,
    Hoping for some advice on the technical side (not my strongest point!).
    I have a SPDIF iPurifier which sits between a Sonos Connect and Cambridge 851N (used as preamp) > Cambridge 851W that I’m really happy with. I am now considering purchasing a Wyred 4 Sound Remedy SPDIF Reclocker which also needs to sit between the Sonos Connect and Pre Amp but that should be fine.
    My simple question is - do the products compliment each other, improving different areas of the signal, or are they essentially doing the same technical job so one cancels the other out (so to speak) - in which case its over-egging everything and no point me purchasing.
    Any advice gratefully accepted!
  2. larkone
    larkone
    Apr 21, 2006
    4,368
    134
    North Essex
    +1,240
