SPDIF input on the AV192R
Discussion in 'AV Receivers & Amplifiers' started by lenny, Feb 16, 2005.
Tags:
  1. lenny
    lenny
    Jul 8, 2004
    435
    Paris
    +6
    Question for the AV192R owners : what digital input are you using on the AV192R for your DVD reader?
    The DVD one or the DVD192 one? Since the output on the DVD readers is usually done with RCA connections (even on the DVD32R/FLR) would it worth to have a cable with an RCA plug on one side and a BNC on the other? Is the DVD192 digital input of a higher quality than the DVD one? Am I cutting the water...?
    Lenny
  2. hoosterw
    hoosterw
    Dec 14, 2004
    16
    in NL near Eindhoven
    Hi there,
    I own a DVD32R and AV192R as well and I personnaly use the DVD-RCA input using a Chord Signature interlink (which I am about to replace BTW).
    I think there would be little advantage for your suggestion, while even 1 RCA will remain the weakest link. I will agree that both BNC would be favourable and that that maybe should have been standard on the DVD32R.
    Rgds
    Hans
