spdif Connect PC to Amp - is this what I need?
Discussion in 'Desktop & Laptop Computers Forum' started by hutters, Jan 24, 2005.
  1. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    I'm just finalising what I need to build my HCPC and need some help on the audio connection.
    From what I've read I need a standard RCA cable with an RCA to 3.5mm jack on the PC end.
    I've had a look on Maplin and I think that I need to buy a cable like this one, but I can't find the jack.
    Am I correct with the cable and can anyone point me to a place where I can buy the necessary jack?
  2. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    Going to be rather a shot in the dark if you don't tell us what sound card you have!
  3. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    Soundblaster Live...does that make a difference as I thought it was just straight passthrough so assumed that any on-board sound with a line out would do the same?
  4. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    What are you plugging it into? stereo amp, surround amp? what connections does it have?
  5. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    I guess that would kind of help too wouldn't it :blush:
    ...it's going into my av amp which has both optical & coaxial digital inputs.
  6. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    Is the Soundblaster live a 5.1 card?
    I had a cheap soundblaster before but ditched it for a second hand card that had an optical out as it made things easier for me.
  7. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    yeah, it's 5.1 but the amp will do all the processing, I just want to pass the digital signal to the amp.
  8. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    Is one of the jacks a digital out? I believe Creative use a jack which doubles as an analogue 3.5mm jack an a mini-toslink
  9. Leporello
    Leporello
    The connection you need, if your Soundblaster Live 5.1 has a digital output, which I think it has, is a 3.5mm jack to phono adaptor (99p Maplins) and a digital coaxial connector to go into the amps' digital in (cost about £12-00 upwards, also from Maplins.
  10. MPK
    MPK
    Nov 26, 2004
    479
    London
    +8
  11. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    Hi MPK, that's not actually the correct cable for what I need - I already have one of those to connect my iPod to my amp.
    As it happens I remembered that I had a digital coax cable so I popped into a music shop at the weekend and picked up a 3.5mm to Phono converter. The sound from the PC was streets ahead of my existing (very old) dvd player so I was very happy :)
