SPDIF cable - from where?
Discussion in 'Desktop & Laptop Computers Forum' started by Brogan, Jul 5, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    I've just realised my sound card has a CD SPDIF connector... :blush:
    I've had a quick search on a few sites but I can't seem to find anywhere that sells a cable for connecting the CD player to the sound card.
    Anyone know where I can get one?
  2. Kramer
    Kramer
    You don't need one as digital audio is transferred over IDE. I wouldn't worry about it ;)
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    D'oh!
    Thanks for that Kramer.
    However, if I select Digital output only from the Creative Audi HQ application, I only get sound coming from the rear surround speakers? :confused:
    As digital audio is transferred across the IDE interface, does that mean I can disconnect the standard analogue cable that is alredy connected between CD and soundcard?
    Damn this upgrading/fiddling... ;)
    EDIT: Just removed the analogue cable and it does indeed work. What are these inputs for then or are they old legacy items?
  4. Kramer
    Kramer
    Yes, they're not needed either. I've used probably a dozen soundcards & even more CD/DVD drives & have never needed any extra connections.
    It's probably a setup or s/ware issue with you Creative. Have a "poke" around in the CP/properties/AudioHQ . IIRC you need to configure the speakers on the 4.1 & certainly most multichannel cards.
  5. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Well that's another new thing I've learned today.
    Removing that cable should help to keep the heat down by 0.1 of a degree ;)
