Spare Bedroom to Dedicated Home Cinema
derekhansen
I’d thought about posting this on the DIY thread as the build progressed but never seemed to get round to it. So with some time off over the Christmas break and the project 99% finished I thought I would showcase the completed project here along with some in progress shots I took along the way.
With the exception of the carpet fitting and final electrical inspection/ test, I did all the work over weekends and evenings between September and mid-December this year
Our house is an Edwardian end of terrace and the converted room was a bedroom that the last of our kids vacated when they flew the nest a couple of years ago. Since then we had been using it as a Gym/Laundry, that was until I had the thumbs up to convert it to a dedicated HT. The room size is 3.90m long x 3.75m wide x 2.75m high.
I wasn’t looking to create a family or media room I just wanted an environment to watch movies in the most favourable conditions possible within a modest budget. The aim was therefore to reduce light reflection and sound transmission as much as possible whilst keeping cost to a minimum.
The visual side of things would be provided by a projector and sound by a 5.1 surround sound with cables installed for a 7.1.2 system in the future.
As I mentioned earlier the budget was very modest. £5500 to be precise and this needed to cover building materials and AV equipment. In the end I spent just over £6000. I initially looked at creating a room within a room utilising acoustic plasterboard, green glue etc. but frankly the cost would have totally bust my budget. In addition I would still need to install acoustic panels to deal with sound reflection.
So I went a different path, one that would incorporate acoustic treatment to deal with sound reflection and improve sound containment as well.
Below is a run-down of what I did.
Floor – floorboards were taken up and de-nailed. 100mm Rockwool RW45 was laid between joists and 6mm thick self adhesive, neoprene tape applied to the top of the joists to de-couple the joists from the boards when screwed back down. All board gaps were sealed with acoustic mastic and finished with Cloud 9 underlay and carpet.
Walls – Three out of the four existing walls are plastered 9” brick. One is a party wall with our neighbour. Although this means I already have a decent amount of mass to prevent sound transmission I still wanted to deal with any sound travelling through gaps (flanking) and further reduce transmission through the wall. At the same time I needed to install sound absorbent treatments to deal with the new sound system. So I applied 50mm RW45 Rockwool batts fitted between 50 x 50mm timber battens. The battens, whose purpose was to provide support for the stretch fabric panelsm, were screwed to the existing walls with rubber grommets separating the battens from the wall surface. The Rockwool was glued to the wall using spray adhesive. The walls were finished with my home made stretch fabric panels. Cables were run in a timber trunking at skirting level.
Ceiling – Over boarded with standard plasterboard. Mainly to cover up the old Artex finish. 100mm RW45 batts were laid in the loft on top of and counter to the joist direction. I also stuffed insulation into gaps and holes wherever I could find them.
Door and Window – I have yet to fit the acoustic seals and absorbent panels to the existing door. I will do this soon as the door is now the main cause of sound leakage.
I think I should say that I have no measured evidence to prove how effective my slightly unconventional approach to sound insulation has been. But, as the primary aim was to provide acoustic treatment rather than construct a sound proof environment I told myself that any improvement in sound containment would be a bonus. Now it’s all done I am very pleased and relieved to say that the room sounds great and the noise has been noticeably contained. I tend to play between -10 and -15db below reference and the bass is noticeable but not obtrusive in adjoining rooms and downstairs.
Below is a list of the AV kit I installed:-
Sony HW45ES Projector suspended from ceiling.
DIY, fixed, 16:9 projector screen, 95” wide.(not sure of the diagonal)
Denon x2400H Receiver.
Oppo B93 Blu-Ray player. (second hand)
Monitor Audio Bronze speakers., L&R front floormounts, with centre and surrounds on stands
B&K P12-300SB DF Subwoofer.
Amazon Firestick for Amazon video and Netflix.
Below are photos of the completed room followed by in-progress shots taken as the work progressed.
derekhansen
Ceiling overboarded
derekhansen
Neoprene strip to dampen the floor board transmission to the joists
derekhansen
Spotlights fitted, ceiling painted and floorboards screwed down.
derekhansen
Projector fitted and image projected on painted wall to establish screen size and position.
derekhansen
Screen support and DIY screen fitted.
derekhansen
Wall battens fitted and acoustic insulation in progress.
derekhansen
Stretch fabric panels in progress.
raoulx
Looks great! I hope your enjoying the new room :D
derekhansen
Room looks great - how did you fix the fabic panels to the walls?
Thank you. The panels were fixed with a combination of self adhesive 2 part Velcro and 40mm panel pins. The pin heads were then painted in with a colour that matched the fabric.
derekhansen
Very much so. I have been watching a couple of movies a day over the Christmas break.
dinoprada2003
Lovely job in particular like the use of velvet / purple it gives a real old school cinematic feel
derekhansen
Thanks. We are very pleased with the look. It really does have a cinematic feel.
Minty
Looks amazing. Nothing quite beats a dedicated cinema room.
Great work and I hope you enjoy it for a long time.
M
Edit Just realised we are the same vintage. 1962 a great year.[emoji1] [emoji1]
derekhansen
Love it, looks brilliant. Congratulations on a great result.
A few questions:
Do you watch in the dark in there?
Does the projector light up the floor much? What carpet did you go for?
What fabric did you go for on the stretch panels?
Thanks. Glad you like it.
To answer your questions:-
1. We watch with the lights off and the black out curtains closed.
2. The carpet is Westex exclusive twist range and the colour is Aubergine. No problem with light reflection. It's quite dark.
3. I used two different fabrics. The rear wall and side walls used a Dark Chocolate colour, cotton velvet fabric from Tissu fabrics, the cost was £7.99 per m. They sell cheaper cotton/Lycra mix velvets but the pure cotton velvet has a matt finish and doesn't reflect the light from the screen. For the screen wall and 1 metre out on the side walls I used Devore Velvet from Whaleys. I cannot remember the exact price but it was approx £15 per m plus delivery and vat. It is expensive but worth it in my opinion as this fabric is very, very black. You need to get the pile/nap in the right direction to avoid it reflecting the light but it really does make the screen wall look like a 'black hole' and certainly improves the perceived contrast of the image. I also used the Devore to deal with the only reflection issue I had which was from the top of the centre speaker. I sorted this out by making a velvet mat to sit on top.
Hope that helps. More than happy to answer any other questions.
jfinnie
Thanks for that, very interesting. I'd assumed the walls were similar in colour to the floor from looking at them, quite deceptive in the photos. Looks really nice.
I think I'm going to either go for a very dark colour on the carpet like you have here or a black. I love purples myself. Also going to be doing the screen wall (and perhaps the back wall) in black, sides undecided as yet (got some fabric samples on the way). A lot of the carpets I like seem to max out at mid greys though which I personally think will rob too much contrast.
I've had Devore samples in the past - as you say it is extremely black!
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
Latest News
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
Sky Q updates smart features and adds Disney Plus in HDR
  • By Andy Bassett
  • Published
