Spanish Television Channel?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by hollie.weimeran, Feb 23, 2003.
  1. hollie.weimeran
    hollie.weimeran
    I don't know if this is in the correct forum but I am trying to find any Spanish television broadcasts that I can pick up in the UK on Sky Digi - can anyone tell me if there are any?
  2. Fernsehman
    Fernsehman
  3. hollie.weimeran
    hollie.weimeran
    Thanks for the help.
  4. Tasos
    Tasos
    Hi Hollie,
    Although there aren't any Spanish channels as such on Sky you can get a spanish soundtrack on Euronews. All you need to do is go to the Language selection menu in the Digibox Menu and set it to Spanish. Doing this won't change the language on any other channels (as far as I know).
    Hope this helps,
    Tasos:D
  5. hollie.weimeran
    hollie.weimeran
    Thanks Tasos, that works a treat - my wifes learning Spanish and needs something of a challenge to understand! (She doesn't understand me either!!!!!)
    Thanks again
