Spanish Sony?
Discussion in 'TVs' started by Blackrat, Jan 28, 2004.
  1. Blackrat
    Blackrat
    Hi all,
    Just a quick question to put my mind at rest:
    At the moment I live in the UK and have a Sony KV32LS36 TV working, of course, on the PAL-I system.
    Sometime this year Ill be moving off to Spain which apparently uses the PAL-BG system.
    Now can anyone tell me if the two are compatable, will my TV, Video,DVD work in Spain or will I have to go for a completely new system, or can I get a converter?
    The things you have to think about when you move house.
    Thanks. :D
  2. Totalnoobee
    Totalnoobee
    Blackrat,
    The only thing you need is a PAL B-G tuner, which you can get in a cheap VCR or depending on where you plan to live you can get a DTT STB and get the same channels but digital. Your VCR and DVD player should be no problem.
