Spade Speaker termination & Denon a10se
Discussion in 'AV Receivers & Amplifiers' started by Gliese 581c, Feb 28, 2003.
Tags:
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    Might sound like a silly question but I'm not sure if i'm thinking correctly ?.... :blush:
    Just bought nordost superflatline gold bi-wire speaker cable and its terminated with plugs and spades.....plugs into speakers (sorry to state obvious) but the spades wont connect to my Denon a10se amp....do they ? am I doing something silly ?
    Let me know.....Thanks:blush:
  2. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    would really like this connected up if possible.....anyone any idea's before i take sissors to the spade and cut it off ?
  3. sounddog
    sounddog
    Dec 11, 2002
    3,440
    107
    Leicestershire, UK
    +477
    This might not help ... but can you insert one lug of the spade through the hole in the binding post before tightening it up ...
    I've never tried this ... but thats how it shows to use spades on the Avia disc (yes okay it was a bit sad to watch that bit of it!!)
    Vikki
  4. Gambit
    Gambit
    The spade will fit around any 4mm speaker terminal, the 4mm plugs will go in your amp. Just un-screw the terminal on the back of your Q55.2's, push the spade around the central post and screw back down. Don't cut the plugs off:eek:
  5. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    gambit.....the spades connect to the amp....Ive got 4 'z' plugs to connect to the speakers with.
    ive got the avia disc too....so i'll check out the part with the spades connection....might be a silly question, but do you know roughly where ?
    thanks
  6. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,768
    On AVForums
    +570
    couldnt wait..... they now cut and fitted with ixos banana plugs.
    damn superflatline gold stuff from nordost is a bitch to strip :mad:
    :smashin:
  7. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
    Did you find that the bass became thin?
