Spaced 1&2 box?
Discussion in 'Movie Forum' started by Lithian, May 25, 2003.
  1. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    I think i remember seeing a box set of Spaced with both S1&2 in it in HMV a while back... but i cant seem to find anything except the separate seasons now.
    Was i just imagining things? Was it an HMV exclusive limited edition sort of thing?
    Gah, i feel the need to watch Spaced again, although i have found the two separate ones for £9.99 each at splash... but, erm, splash. :rolleyes:
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    I remember seeing something like this, although I think it was just that. A box, no other extra's.
    Great series too.
    Anyone know if a third series is being made?
  3. Duncan Craig
    Duncan Craig
    Edgar Wright is an old associate of mine.
    He said in an e-mail to me that they were hoping to make more ! hope so, cos it was sooooo very very funny.
    "Cheese Sandwich"
  4. chard
    chard
    Dec 12, 2002
    398
    16
    spaced 2 is in the bargain section at Play for 8.99, you should be able to find the first series for similar....definately worth buying as it is so rewatchable
  5. Links
    Links
    Dec 12, 2002
    108
    +5
    Both series' are part of the "3 for £20" promotion in my local Virgin Megastore (Bromley). Just so you know.
    "Jar Jar Binks makes the Ewoks look like ****ing Shaft." Brilliant.
  6. Lithian
    Lithian
    Jan 16, 2003
    38
    9
    Edinburgh 3
    Thanks all, I will pop along to Virgin tomorrow and see what i can see.
    I think monkeyboy73 was right, it was just them grouped together (I think the box was £25 or something, when both series were £15 each in the shops)
  7. KRRK
    KRRK
    Simon Pegg has been quoted as saying there will be a third season.
  8. rhoamish
    rhoamish
    I've had Series 2 for a while now, but I only recently bought series 1 from play.com last week.
    Brilliant! Even better than the second series. Tyres is a totally inspired creation!
  9. bobbles
    bobbles
    I believe the box set was an HMV exclusive
    great series
  10. Azrikam
    Azrikam
    Yep, I recently picked up Season 1 and 2 from Play for £8.99.
    Oh, and if you don't know, Simon and Edgar are filming a Romance/Zombie/Comedy movie right now. (Shaun of the Dead... get it?) Not sure when it'll be released, but it'll definitely be on my "must buy" list, as I'm going to be one of the zombies. :smashin:
